12/9/2008 9:29 AM | |
Joined: 5/8/2006 Last visit: 1/29/2021 Posts: 1085 Rating:
Hi, you cannot use a tag multplexingin connection witha trend control but you can use address multiplexing. Maybe this FAQ will help you: http://support.automation.siemens.com/WW/view/en/21808321 If you change the address of the curve the first curve is combined with the second curve. This methode falsify your curves. So, it' s better to use more Trend views. With the animation "Visibility" it is possibleto showthe relevantand irrelevent curve and Trend viewrespectively. In this conection you can use tag multiplexing. Maybe this FAQ will help you: http://support.automation.siemens.com/WW/view/en/21807421 Bye |
