9/27/2007 3:28 PM | |
Posts: 1776 Rating:
Hi, see FAQ http://support.automation.siemens.com/WW/view/en/24740744 April |
9/30/2007 9:27 AM | |
Posts: 84 Rating:
Copy your horn into horn folder in wincc project. It should work if you read full and carefully the link below. http://support.automation.siemens.com/WW/view/en/24740744 otherwise check your sound card is ok, and if not you may reinstall WINCC i think. no idea Good luck |
10/1/2007 5:12 PM | |
Posts: 35 Rating:
Hi, The sound was allready in Horn folder! I simply reinstall WinCC and it started to work fine (Informatic solution sometimes really works Thanks |
