9/21/2006 6:30 PM | |
Posts: 1275 Rating:
All the computers have the exact same software,with the same versionand project? |
9/21/2006 7:12 PM | |
Posts: 33 Rating:
That is correct, all were configured and set up on the same date with the same software on the same physical platforms. |
9/21/2006 7:21 PM | |
Posts: 1275 Rating:
What is the operation system? Which version of WinCC and Simatic Net do you have? |
9/21/2006 10:27 PM | |
Posts: 33 Rating:
Chris, I have the Redundancy option installed, so by opening the Redundancy window all I have to do is make sure that the "Activate Renduncancy" checkbox is unmarked. Something weird happened here, though: I created an archive, saved it and deleted it later on, while making tests. Some time later I got a message of expiration for demo mode. WinCC Explorer recognized my 64K license, but the logs showed that it was searching for an UA license, even though my archive had been deleted and User Archives was no longer being initiated. I shut down WinCC and re-opened it, and it was all good again... ![]() Can you post your license log here? This is pretty long, I hope it helps. I do nothave the option in the start up to uncheck "activate redundancy" but I do for "User Archives". I unchecked "User Archives" and it still states that I need a license for it. I'm not worried as much about the "User Archives" as I think I may need it later on in this project, but the Redundancy is another story. I tried what you stated above and WinnCC still doesn't like me. [:(] If you have any other ideas, please let me know... Thanks again, -Chris License log:(also in .csv format in attached .zip file) "Product";"Version";"Action";"Source";"Target";"End time";"Result";"User";"License number";"License type" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/09/21 13:35:14.867";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/09/21 13:34:11.432";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/09/21 13:28:32.342";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/09/21 13:25:11.335";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/09/20 16:19:10.359";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/09/20 16:15:45.246";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/09/20 16:08:52.754";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/09/20 16:03:36.040";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/09/19 16:13:38.294";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/09/19 15:57:50.459";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/24 12:14:09.430";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/23 14:14:21.463";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/23 14:01:36.669";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/23 14:01:27.749";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/23 14:00:49.190";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 17:49:41.834";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 17:46:33.364";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 17:28:34.022";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 17:28:07.464";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 17:01:56.495";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 16:51:37.994";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 16:02:49.584";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 15:54:34.994";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 10:58:11.407";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/22 10:52:46.376";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/19 16:11:41.695";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/19 15:59:28.635";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/16 08:39:37.965";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/13 17:54:38.742";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/13 17:49:59.550";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/13 17:03:33.294";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/13 16:59:58.442";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/13 14:48:19.294";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/13 14:44:43.253";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/10 15:28:34.885";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/10 15:27:15.599";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/08 17:31:57.200";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/08 17:31:26.313";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 23:06:26.953";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 23:06:13.644";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 21:45:53.913";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 21:39:00.246";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 21:38:47.539";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 21:38:30.188";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 20:22:06.392";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 20:21:49.969";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 19:18:57.041";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 18:58:16.677";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 15:05:06.772";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 15:04:47.093";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 15:03:37.997";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 14:40:40.269";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 14:31:53.308";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/06 14:31:00.604";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/04 11:13:49.525";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/04 10:13:49.007";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/08/03 11:30:46.823";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/08/01 17:22:38.397";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/07/19 10:26:34.498";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/07/18 17:48:45.739";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/07/17 14:46:55.003";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/07/17 14:39:31.577";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/06/20 10:00:18.014";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/06/20 09:55:21.268";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 16:22:56.813";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Release";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 16:19:42.590";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Assign";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 15:02:11.812";"";"LBW2\Administrator:0";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Transferred (3/4): Cut license key";"LBW2 - A:\";"LBW2 - A:\";"2006/06/19 14:52:51.518";"";"LBW2\Administrator";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Transferred (4/4): Insert license key";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 14:52:51.518";"";"LBW2\Administrator";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Transfer";"LBW2 - A:\";"LBW2 - C:\";"2006/06/19 14:52:51.518";"";"LBW2\Administrator";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Transferred (2/4): Determine request code";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 14:52:39.983";"";"LBW2\Administrator";"00401000065050355228";"Single" "WinCC RT (65536)";"6.0";"Transferred (1/4): Determine metadata";"LBW2 - A:\";"LBW2 - A:\";"2006/06/19 14:52:39.963";"";"LBW2\Administrator";"00401000065050355228";"Single" "SIK/SIMATIC NET SNMP OPC-Server Extended";"";"Transferred (4/4): Insert license key";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 14:34:20.990";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Extended";"";"Transfer";"LBW2 - A:\";"LBW2 - C:\";"2006/06/19 14:34:20.990";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Extended";"";"Transferred (3/4): Cut license key";"LBW2 - A:\";"LBW2 - A:\";"2006/06/19 14:34:20.980";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Extended";"";"Transferred (2/4): Determine request code";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 14:34:06.663";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Extended";"";"Transferred (1/4): Determine metadata";"LBW2 - A:\";"LBW2 - A:\";"2006/06/19 14:34:06.653";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Basic";"";"Transfer";"LBW2 - A:\";"LBW2 - C:\";"2006/06/19 14:32:45.495";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Basic";"";"Transferred (3/4): Cut license key";"LBW2 - A:\";"LBW2 - A:\";"2006/06/19 14:32:45.495";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Basic";"";"Transferred (4/4): Insert license key";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 14:32:45.495";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Basic";"";"Transferred (2/4): Determine request code";"LBW2 - C:\";"LBW2 - C:\";"2006/06/19 14:32:31.189";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET SNMP OPC-Server Basic";"";"Transferred (1/4): Determine metadata";"LBW2 - A:\";"LBW2 - A:\";"2006/06/19 14:32:31.169";"";"LBW2\Administrator";"0100000000";"Single" "SIK/SIMATIC NET S7-REDCONNECT";"";"Transferred (4/4): Insert license key";"LBW2 - C:\";"LBW2 - C:\";"2006/04/07 14:27:04.890";"";"LBW2\Administrator";"0131400927";"Single" "SIK/SIMATIC NET S7-REDCONNECT";"";"Transfer";"LBW2 - A:\";"LBW2 - C:\";"2006/04/07 14:27:04.890";"";"LBW2\Administrator";"0131400927";"Single" "SIK/SIMATIC NET S7-REDCONNECT";"";"Transferred (3/4): Cut license key";"LBW2 - A:\";"LBW2 - A:\";"2006/04/07 14:27:04.880";"";"LBW2\Administrator";"0131400927";"Single" "SIK/SIMATIC NET S7-REDCONNECT";"";"Transferred (2/4): Determine request code";"LBW2 - C:\";"LBW2 - C:\";"2006/04/07 14:26:50.619";"";"LBW2\Administrator";"0131400927";"Single" "SIK/SIMATIC NET S7-REDCONNECT";"";"Transferred (1/4): Determine metadata";"LBW2 - A:\";"LBW2 - A:\";"2006/04/07 14:26:50.599";"";"LBW2\Administrator";"0131400927";"Single" AttachmentMyWinCC.zip (96 Downloads) |
