3/16/2023 11:38 AM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello Chris Lari how do you read the Tag value in the Script? You could try a direct reading: https://support.industry.siemens.com/cs/ww/en/view/109815056/36120935051 This stops the script and runs again only if the current value from PLC is readed. It slows down the script a little bit but could probably clear this update behaviour. Bye Murof |
