11/14/2023 12:16 PM | |
Joined: 5/30/2022 Last visit: 4/25/2025 Posts: 634 Rating:
Hi Marko_Petrivic, I propose you 2 solutions to try to solve your problem according to my personal experience: 1- Make a copy of the project, delete the project IM folder and recompile from new software and hardware: How do you delete the IM folder of your STEP 7 (TIA Portal) project? 2- Delete that Script, delete the calls to the Script, compile, after the compilation is successful, add back the Script and the calls.
If this information really helps, you could use the Rate function. |
