9/1/2023 9:29 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Kevin This conference is not the right desition for your question (SIMATIC WinCC(TIA Portal), would be the right one). -> the KTP700 (Basic or Mobile??) I suppose Basic, does not have a online diagnostic interface, so the going Online Status is not an indicator if the Panel is OK. -> If the panel does not work as supposed You should do a reset to factory settings and transfer the TIA Portal HMI Project again to the Panel. The Basic Panels 2nd Generation uses a USB Recovery: https://support.industry.siemens.com/cs/ww/en/view/109744950 Bye Murof |
