10/28/2008 8:27 AM | |
Posts: 4 Rating:
I am using @CCOnlineTrendCtrl-Curves-CP.RPL trend report page layout. In the attached report my requirements are: 1. I want onlytwo scales at Y-Axis:- for pressure measuring from -1 to 3 bar & for temperature measuring from 20 to 130 deg C.Since i have total 4 temperature parameters and because pressure and temperature have different scale, i am not able to use common Y-axis option. 2. The time axis should be tag dependent, i.e. it should start from when my binary RUN bit goes high and till RUN bit goes low. Even though i assigned tags in Dynamic parameters for start time and end time, it always take the time axis conditions from Assignment parameters. AttachmentTrend.pdf (38 Downloads) |
10/28/2008 9:46 AM | |
Posts: 52 Rating:
hello, 1. combining several equal y-axis is only possible in wincc v7 if i remember correctly. greetz |
