2/4/2025 1:48 PM | |
Joined: 1/21/2013 Last visit: 2/12/2025 Posts: 3537 Rating:
Hi John36, Which HMI device are you using? The available ODBC drivers listed in the manual are for Unified Comfort Panel. In the case of WinCC Unified PC Runtime, you need to specify an ODBC driver that is installed on your computer. And for a WinCC Unified Comfort Panel, you need to know that the installed ODBC drivers depend on the image version. Older image versions use the ODBC driver 17. Kind regards |
2/4/2025 2:24 PM | |
Joined: 4/2/2015 Last visit: 2/12/2025 Posts: 22 Rating:
Hi, |
2/5/2025 7:37 AM | |
2/5/2025 7:40 AM | |
I instaled ms sql server 2019 on the another computer. I will try connect WinCC with it. |
