6/8/2009 10:41 AM | |
Posts: 11 Rating:
thanx for reply Please update meany documentation available for the same |
6/8/2009 1:18 PM | |
Posts: 11 Rating:
Hi, I want to dynamize pipes please find attached screens in PDF format for a review Thanx Anil AttachmentScreens.pdf (97 Downloads) |
6/10/2009 1:14 PM | |
Joined: 4/5/2006 Last visit: 9/15/2023 Posts: 917 Rating:
Hi cool_anil, if you have to change color and flashin only, better you use "Dinamic Dialog" properties instead "C function" (customizing object maybe). As well as Dariussaid, you have to pai attention when you use scripts. They take affect in different way depending how developed: not only fromtime update, it's depend what did you do inside function (p.e. read variable from plc or call ather subfunction ... ) I seen you have not so heavy graphic page but lot of pipes, try to use Dinamic Dialog at first and use C function for what is not possible with it Regards |
