5/4/2022 6:38 PM | |
Joined: 7/2/2015 Last visit: 4/24/2025 Posts: 96 Rating:
Hello C-3PO, |
5/5/2022 4:18 PM | |
Joined: 5/30/2014 Last visit: 4/25/2025 Posts: 170 Rating:
I tried that, but nothing happened. What is even worse, besides screens, I noted that runtime objects (in WinCC RT Simulator) "run away" toward left upper corner! Two heaters are moved slightly (but notably), and the boiler is completely off the place!
Last edited by: C-3PO at: 05/05/2022 16:19:09Last edited by: C-3PO at: 05/05/2022 17:05:59If you find my contribution helpful please RATE it :)) |
