7/28/2023 10:20 AM | |
Hello Enia Yes here are this information again in a FAQ: https://support.industry.siemens.com/cs/ww/en/view/34473263 This is based on WinCC V7 but also is the same in WinCC Prof. But 45 Minutes are way to long... check also if you use the latest Updates and look in the Diagnose folder of WinCC what takes this long to activate at startup of Runtime. Bye Murof |
