4/14/2022 1:13 PM | |
Joined: 11/25/2021 Last visit: 1/4/2023 Posts: 6 Rating:
Any idea what is the real problem? I did repair, also i turned off the Windows firewall. still the issue is same. |
4/22/2022 8:36 AM | |
Joined: 8/3/2009 Last visit: 4/24/2025 Posts: 15350 Rating:
Hello if you are using WinCC Professional you should first check your Systems (ES and OS) with this FAQ: https://support.industry.siemens.com/cs/de/en/view/108464289 (check all points also lmhosts and so on...) Then check this FAQ: https://support.industry.siemens.com/cs/ww/en/view/88780011 If it do not work any more you could also use PlanB: https://support.industry.siemens.com/cs/ww/en/view/103198851 Bye Murof |
