3/8/2023 12:29 PM | |
Joined: 8/3/2009 Last visit: 4/24/2025 Posts: 15350 Rating:
Hello RGProg I would try to reset the temporary HMI files in the Project: https://support.industry.siemens.com/cs/de/en/view/109778709 If this does not help then try with another test project f this only dows not work with this special project. bye Murof |
8/9/2024 9:15 AM | |
Posts: 1 Rating:
For me the issue went away when I closed PLCSIM |
