10/2/2015 5:55 PM | |
Joined: 9/23/2005 Last visit: 5/27/2022 Posts: 4087 Rating:
“Simple Samples” are small projects that demonstrate simple features. The target is give a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps.
Description:
Beside of the RGB color composition, VB and C haven constants that represents the main colors.
By clicking on a button, objects change its colors in accordance with these constants.
Notes: the objective here is not show how to set color in objects itself (there are several ways to do it), but just to presents the colors constants.
Requirements: WinCC Professional V13 SP1.
Configuration main steps:
Colors constants for C Scripting
Colors constants for VB Scripting
References: Manual WinCC Professional V13.0 https://support.industry.siemens.com/cs/br/pt/view/92323076/en
Online helps system WinCC Professional V13.0 SP1 https://support.industry.siemens.com/cs/br/pt/view/109096785/en
FAQ How do you use scripts to dynamize objects in WinCC Comfort and WinCC Advanced? https://support.industry.siemens.com/cs/br/pt/view/53752382/en
Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/br/pt/view/59885894/en
Tips and tricks for creating scripts in WinCC (TIA Portal) https://support.industry.siemens.com/cs/br/pt/view/57132412/en
Project: as data.zip.
AttachmentProject2.zip (200 Downloads) |
Denilson Pegaia |
