2/20/2020 8:33 AM | |
Hello Rahul Check this FAQ out, its primary for WinCC Classic but basically it should also work for winCC Professional in TIA: https://support.industry.siemens.com/cs/ww/en/view/6836122 Bye Murof |
2/21/2020 4:31 PM | |
Posts: 49 Rating:
Thanks Problem solved using restart the PC and open corresponding RT file again. |
