2/14/2020 1:17 PM | |
Posts: 49 Rating:
NEED HELP ON WINCC PROFESSIONAL V16 SCRIPT after the compile error in dim dataset line, please help. my project script as shown as below. Function Script_3() 'NOTE: To start scripting please press <Ctrl><Space> and see the wide variety of functions. 'Write scripts by using system functions or the WinCC flexible object model. You can easily access to the 'system through the HMI runtime object. For a convenient picking of an object reference 'you can press <Alt><Right Arrow>. Design complex scripts by employing the basic features 'of the programming language VBScript and access tags directly by name e.g. tag = 5. Dim fso Dim f Dim N Dim TimeIt Dim ts Dim path Dim StopArchive Dim EleNo Dim DataSet Dim Header Dim Shift Dim ShiftNo Dim BundeNo Dim TimeS Dim TimeStamp Dim StartArch Dim exten Dim StartTime, EndTime,flag,diff If exten=0 Then path = "E:\REPORTS\" & "STEAM STERILIZATION LAB UNIT" & CStr(DatePart("yyyy",Date))&"_"&CStr(DatePart("m",Date))& ".csv" End If Set fso = CreateObject("Scripting.FilesystemObject") If Not fso.FileExists(path) Then fso.CreateTextFile(path) SmartTags("HEADER")=0 End If Set f = fso.GetFile(path) Set ts = f.OpenAsTextStream(8,-2) Header=SmartTags("HEADER") If Header=False Then ts.WriteLine "DATE,TIME ,BATCH COUNTER, BATCH TIME(Min),VACUUM PRESSURE(Bar),SHELL INSIDE TEMP(°C),PRODUCT -1 TEMP(°C), PRODUCT-2 TEMP(°C),STERILIZATION ROOM TEMP(°C),STEAM PRESSURE (Kg/Cm2), STEAM TEEMP(°C),TEMP PID SV(°C), TEMP PID PV(°C), TEMP PID MV(%),TEMP PID GAIN(%),TEMP PID Ti(Sec), TEMP PID Td(Sec),VACUUM PID SV(Bar),VACUUM PID PV(Bar),VACUUM PID MV(rpm),VACUUM PID GAIN (%),VACUUM PID Ti(Sec),VACUUM PID Td(Sec)" SmartTags("HEADER")=1 End If While(1) 'Call TimeIt(5) flag=True StartTime = Timer While(flag) EndTime = Timer diff=EndTime-StartTime If diff>60 Then flag=False End If Wend DataSet =Date & ","& Time& ","&SmartTags("BATCHSTARTSTOPDB_BATCHCOUNT")& ","&SmartTags("BATCHSTARTSTOPDB_BATCHTIME_TOTALMIN")& ","&SmartTags("AISCALINGDB_VACUUMPRESSURE")& ","&SmartTags("RTDSCALINGDB_INSIDESHELLTEMP")& ","&SmartTags("RTDSCALINGDB_PRODUCTTEMP-1")& ","&SmartTags("RTDSCALINGDB_PRODUCTTEMP-2")& ","&SmartTags("RTDSCALINGDB_ROOMTEMP(STERILIZATION)")& ","&SmartTags("AISCALINGDB_STEAMPRESSURE(1)")& ","&SmartTags("RTDSCALINGDB_STEAMTEMP")& ","&SmartTags("TEMPPIDDB_SPINTERNAL")& ","&SmartTags("TEMPPIDDB_PV")& ","&SmartTags("TEMPPIDDB_PIDOUT")& ","&SmartTags("TEMPPIDDB_GAIN")& ","&SmartTags("TEMPPIDDB_Ti")& ","&SmartTags("TEMPPIDDB_Td")& ","&SmartTags("VACUUMPIDDB_SPINTERNAL")& ","&SmartTags("VACUUMPIDDB_PV")& ","&SmartTags("VACUUMPIDDB_VACUUMPIDOUTPUTRPM")& ","&SmartTags("VACUUMPIDDB_GAIN")& ","&SmartTags("VACUUMPIDDB_Ti")& ","&SmartTags("VACUUMPIDDB_Td") ts.WriteLine DataSet Wend ts.Close Set fso = Nothing Set f = Nothing Set ts = Nothing Timer End Function ------------------------------------------------------------------------------------------ |
2/14/2020 5:06 PM | |
Posts: 49 Rating:
Please help me sir for my problem |
2/14/2020 11:23 PM | |
Joined: 9/1/2005 Last visit: 4/10/2025 Posts: 4113 Rating:
closed cause question posted twice. sdfa The second thread with the subject NEED HELP ON WINCC PROFESSIONAL V16 SCRIPT is published within the same conference SIMATIC WinCC (TIA Portal) Best regards |
