12/1/2020 8:16 AM | |
Posts: 1 Rating:
Hello all, I'm trying to re-install TIA-Portal v16 including WinCC Professional. Following the manual, I first removed the instance of the existing SQL server WinCC instance. During the installation I encounter an error though, saying "Instance Name WINCC for product Microsoft SQL Server doesn't exist" (Log file is included). I was under the impression the SQL server instance would be newly created at the install of WinCC Professional. Now the installation is aborted and I can't use anything. Does anyone have a solution for this? Thanks in advance. AttachmentSIA_STEP7_S7FPLUS_WINCC_PRO_V16@20-12-01_08-00-57_summary.txt (285 Downloads) |
