8/21/2023 5:44 PM | |
Joined: 5/30/2022 Last visit: 4/16/2025 Posts: 634 Rating:
Hi FM_Merse1, I haven't found an example for WinCC Professional, but the procedure is the same as for WWinCC V7.x, I hope this example will help you: How do you set up WinCC Audit? How do you select the Audit Trail Server and create a database? |
If this information really helps, you could use the Rate function. |
8/31/2023 2:24 PM | |
Joined: 2/17/2020 Last visit: 4/16/2025 Posts: 1250 Rating:
Hi, You could also follow this section of the GMP Engineering manual for RT Professional: GMP Engineering Manual SIMATIC WinCC (TIA Portal) V15 > Configuration for WinCC RT Professional |
A rating will be well appreciated. |
2 thankful Users |
