9/6/2022 9:24 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Kahio you should work with an echrypted user defined Port in Simatic Shell (then you can also open this specified ports in the firewalls). Also you should use Multicast Proxy (one PC from each subnet or network segment must act as Multicast Proxy) Also check the basic FAQs for direct or indirect project transfer: https://support.industry.siemens.com/cs/ww/en/view/88780011
Bye Murof
