4/29/2009 11:18 AM | |
Joined: 4/24/2006 Last visit: 12/12/2024 Posts: 8783 Rating: (1172) |
Hi, Have you seen this link: http://support.automation.siemens.com/WW/view/en/11841504 Best regards, Wizard |
4/29/2009 11:40 AM | |
Posts: 33 Rating: (0) |
Thanx aru, reading it now. Yes Wizard, I saw that FAQ but it does not compare both methods... anyway thanx. |
6/7/2009 1:09 PM | |
Posts: 25 Rating: (0) |
Another screen shot of an essentialunavailable OPTION ( OS ) in my Software is enclosed here! |
6/7/2009 8:12 PM | |
Joined: 3/18/2009 Last visit: 12/6/2024 Posts: 306 Rating: (94) |
Hi InnocentGuy, It looks like you installed WinCC first and then Step 7. Am I presuming correct? In cases where WinCC installation is done before Step 7, AS-OS engingeering option is to be installed from WinCC installation DVD after you have completed your Step 7 installation. Please follow installation procedure described in thisthreadand also have a look at this FAQfor some screen shots. The options you are looking for should be available after the installation of thes option.
6/8/2009 9:41 PM | |
Thank you so much dagafor your generous help.Its is done. Thanks once again :) |
