6/1/2007 12:23 AM | |
Joined: 5/19/2006 Last visit: 11/29/2023 Posts: 548 Rating:
Use any Modbus OPC Server and then use WinCC OPC Client Channel to get the meter readings. Dec |
6/1/2007 1:05 PM | |
Posts: 1275 Rating:
Hi, As Dec said, the best way to do this is using a modbus OPC Server and the WinCC OPC Client. Your meter will communicate with this Modbus OPC Server. The Modbus OPC Server communicates with the WinCC OPC Client Channel, which is how WinCC gets the tags. A manufacturer we use, which has this solution is Kepware... but of course, there are maaaaaany others out there! Best regards, Danielle |
