9/24/2019 7:07 PM | |
Joined: 11/13/2013 Last visit: 12/8/2024 Posts: 35 Rating:
UPD: OPC UA connection work fine In the WinCC RT Adv V14. The problem is only with WinCC RT Adv v15.1 |
9/30/2019 6:17 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello also if you have set no security and not encryption please have a look in the rejected folders of the Runtime, in some cases you also have to do a certificate trustment., Here ist the BASIC_FAQ Bye Murof |
