11/13/2023 9:07 AM | |
Hello jrabaya WinCC Professional has no implemented optin Audit, but you can use sysemfunctions and workarounds to get this use case: https://support.industry.siemens.com/cs/de/en/view/109766369 (I do not know a never version of this manual, but works also in newer TIA Versions) Bye Murof |
