7/31/2024 1:00 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello SamiCAN42 you can use the ruler of the Trend Control: https://support.industry.siemens.com/cs/de/en/view/50353471 The FAQ is for WinCC V7 but it works also the same way in WinCC Prof. There is also the GertRulerData Method ByeMurof |
