4/17/2025 6:46 AM | |
Joined: 8/3/2009 Last visit: 4/28/2025 Posts: 15368 Rating:
Hello If you use a OPC DA Server (DCOM-based -> No OPC UA!!) then you have to care about DCOM settings: https://support.industry.siemens.com/cs/ww/en/view/109768431 https://support.industry.siemens.com/cs/ww/en/view/109763316 WinCC Professional has integrated a OPC DA (DCOM) Client Channel. Bye Murof |
