3/28/2025 10:52 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello andrii.mahda If you only work with the Simulation then check out this FAQ: https://support.industry.siemens.com/cs/ww/en/view/109810854 But of course the license should work. If cannot get it work I suggest opening a Service request. Bye Murof |
