9/14/2017 8:31 AM | |
Joined: 4/24/2006 Last visit: 4/25/2025 Posts: 8969 Rating:
Hello, Perhaps this link might help: How do you configure the WinCC Autostart for WinCC flexible Runtime? Best regards, Wizard |
9/22/2017 11:26 AM | |
Posts: 648 Rating:
This wizard is for the WinCC RT Advanced Autostart. You have to define which source should be use for RT. You can define it. Press button "Ja" to define the path and file. Alternativ you can use this FAQ: https://support.industry.siemens.com/cs/ww/en/view/58565180 |
6/15/2020 2:22 PM | |
Joined: 9/23/2019 Last visit: 7/16/2024 Posts: 10 Rating:
I'm having the same challenge. From what you say which folder will I locate to define the path
9/15/2022 9:23 AM | |
Joined: 3/15/2015 Last visit: 4/24/2025 Posts: 15 Rating:
I am also having the same problem. Anyone find a solution? |
9/22/2022 8:23 AM | |
Thank you very much Murof, everything is good right now. |
