12/17/2012 4:24 PM | |
Posts: 3037 Rating:
Hello, You transfer your project from Project-PC to your Runtime-PC. https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=41583856907&Language=en-US&TopicId=12289595659 Tweety |
12/18/2012 2:50 AM | |
Posts: 37 Rating:
Hi Tweety I try to download to PC Runtime but download fails.
12/18/2012 8:22 AM | |
Posts: 37 Rating:
Hi Tweety I am download project to PC other, but it error alarm. I install full software Wincc Professional V11 SP2 Can you help me . Thanks |
12/18/2012 2:09 PM | |
Posts: 3037 Rating:
Hello, You should use on both PC the same user with administrator rights and the same password. The user has to be in the group "SIMATIC HMI". What are the requirements for the operation of SIMATIC WinCC in a Windows network? What should you watch out for when downloading from the WinCC/PCS 7 Engineering Station to the Operator Station (ES-OS download)? Tweety |
12/19/2012 8:30 AM | |
Posts: 37 Rating:
hi Tweety I install WinCC Runtime Professional V11 SP2, but IT error. Can you help me
12/19/2012 8:31 AM | |
Posts: 37 Rating:
Error |
12/19/2012 11:28 AM | |
Posts: 3037 Rating:
Hello, Do you check all my infos in the last post? If the download does not work, you start a support request. ----> support request Tweety |
7/3/2013 12:13 PM | |
Joined: 9/2/2012 Last visit: 12/29/2022 Posts: 711 Rating:
dearnguyenvudtd, is your problem solved ?? please update the procedure of download that you followed ... regards vipz
