8/22/2007 1:02 PM | |
Posts: 3149 Rating: (171)
Hi in WinCC you can design Faceplates as well.For PCS7 you can check this manual http://support.automation.siemens.com/WW/view/en/24449702 you should search the FAQs for "Wincc picture window" http://support.automation.siemens.com/WW/view/en/24193022 http://support.automation.siemens.com/WW/view/en/22786810 http://support.automation.siemens.com/WW/view/en/23130772............ nemo |
9/8/2017 11:46 AM | |
Joined: 8/21/2014 Last visit: 12/9/2024 Posts: 1024 Rating: (14) |
New question published by Eng Muhammed Adel is split to a separate thread with the subject Iam working on a SCADA project using TIA wincc v14 . I want to make a header screen which will be fixed on all or some screens ?. Best regards |
