9/16/2014 7:13 AM | |
Posts: 1299 Rating:
Hello, at which step do you get this error? Do you try to open a project in the engineering system? do you try to start runtime on server/ on client? K!ke |
9/19/2014 7:59 AM | |
Posts: 1299 Rating:
Hello, In my case this was the solution... did you try it? K!ke |
9/7/2016 12:27 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4837 Rating:
New question published by JDarius is split to a separate thread with the subject Use engineering PC as a second client. Best regards |
