3/17/2009 5:03 PM | |
Hi That should function Dim 1A_CRM1 Dim 1B_CRM1 Dim CRM1
Learn more about visualization - visit the HMI courses of Siemens AG! |
3 thankful Users |
8/19/2013 9:50 AM | |
Joined: 10/3/2010 Last visit: 9/6/2023 Posts: 1552 Rating:
If AMPS_1 is your WinCC tag with address DB2.DBD500, you should change your script line to Set AMPS_1 = HMIRuntime.Tags("AMPS_1") instead ofSet AMPS_1 = HMIRuntime.Tags("DB2.DBD500") |
B r g d s , |
4/14/2015 5:10 PM | |
Posts: 4 Rating:
Thank you for good simple example. |
1/20/2018 6:59 AM | |
Posts: 6 Rating:
That's very helpful to us. Thanks for your share. 🇧🇩🇧🇩🇧🇩📌 |
1/30/2019 1:57 PM | |
Joined: 5/24/2017 Last visit: 9/7/2023 Posts: 10 Rating:
On the line Set CRM1 = HMIRuntime.Tags("CRM1_1") is wrong. Set CRM1 = HMIRuntime.Tags("CRM1") is OK. Regards. |
