12/22/2020 9:14 AM | |
Joined: 2/6/2015 Last visit: 4/4/2025 Posts: 80 Rating:
Hello Sampathkumar007s, If you want display tag values in a table you could use the "Table View". This object represents these values of your TagLogging tags. Look at this part of manual: Configuring the Table View (RT Professional) https://support.industry.siemens.com/cs/ww/es/view/109755202/22211459467?dl=en Best Regards, CGA81 |
12/22/2020 10:52 AM | |
Joined: 7/5/2013 Last visit: 4/23/2025 Posts: 3148 Rating:
Hi SAM, or if you are using RT Advanced (as in your other post), then check the Toolbox for HMI projects: Table View for Logs. Regards, Frink |
Pi is exactly three! |
