7/25/2007 1:45 PM | |
Posts: 1275 Rating: (123)
Hi, You can edit not only tags, but also structures, alarm classes, messages, tag logging and all, with Configuration Tool. It comes with WinCC for free, just check the "Additional software" part of your WinCc installation CD... You'll be able to create projects with Configuration Tool, or export data from you current project, edit in Excel and transfer the changes back to your project... About sending the DB's from Step7 to WinCC you can check this FAQ. Also... I've seen some threads in the forum about this... have you searched there? Best regards, Danielle |
7/25/2007 2:39 PM | |
Joined: 11/3/2006 Last visit: 11/24/2024 Posts: 11 Rating: (0) |
You need just run the setup & add new component... |
