10/17/2014 8:06 AM | |
Posts: 1299 Rating: (136)
Hello, Which runtime system do you like to use? do you use a panel or a pc system? K!ke |
10/17/2014 9:07 AM | |
Posts: 61 Rating: (0) |
PC system |
10/20/2014 7:46 AM | |
dearK!ke thanks for informative reply. another thing i want to ask is that does Wincc TIA portal V13 have boht runtime and engineering software pakage with One license?if yes kindly tell me order code. on siemens website i notice that i have separate runtime and engineering software license |
10/22/2014 9:07 AM | |
Hello, here you can find the different order numbers for WinCC TIA Portal Engineering: http://support.automation.siemens.com/WW/view/de/85119447?Datakey=47069298 and for wincc runtime advacned: http://support.automation.siemens.com/WW/view/de/85121276?Datakey=47069298 K!ke |
