9/9/2014 8:34 AM | |
Posts: 1299 Rating: (136)
Hello, you find the files with windows explorer just search for "*.rpl". But I would recommend you to save the original files before changing something K!ke |
9/16/2014 7:28 AM | |
Hello, I only know the solution for wincc v7. didn't try it with tia portal so far. http://support.automation.siemens.com/WW/view/en/26414441 If it's not possible you can also make your own report and add the print button manually. If you don't want to have an "external" button for this issue, you can also change the original toolbar of the control: http://support.automation.siemens.com/WW/view/en/76327375 K!ke |
7/18/2019 10:23 AM | |
Posts: 2 Rating: (1) |
Hello! |
