1/21/2009 10:08 AM | |
Hello Just an idea. Install a PDF-generator and select thePDF-generator as printer,so you can save your prints. Also you can export the tag with the tag logging control to excel(.csv). Can you diccribe want you exactly need? Like : I want to store the tags form the last hour. I want to store the tage between to times. Do you will input the times? Something like that. I think i can help you. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
1/28/2009 2:17 PM | |
Hi praveen.pg Why you want to work with the database? I thing its not nnecessary. You want to store tag between tow times and that every minute, hour,..in an excel sheet, did i understand you right? I never made this, but i think, you can use the export funtion of the trend control. There you canshow the tags between the two times and you can export this selection in an csv-File(excel). When you work at the database you haveknowexactly, what you are doing. regards cumulus |
3/17/2014 7:14 PM | |
Posts: 341 Rating:
new question is splittet to read specified time range Archive Tag data and write them to Excel using VBA script. |
