4/8/2025 10:54 PM | |
Joined: 6/30/2018 Last visit: 4/14/2025 Posts: 11 Rating:
Hi, I'm using Wincc unified V17. Like you mentioned, i can able to toggle the visibility of the Button button from outside, how to control the function of the particular element button. for example , i want to pause and play the trend control which is the function of Element[2] in the trend control. The problem is ExecuteToolbarButton method is not available in wincc unified v17. i need an alternate for that! please help me with this, Thanks in advance!! Prasadh ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 04/09/2025 08:27:07New subject after splitting |
