2/12/2025 2:50 AM | |
Joined: 9/22/2023 Last visit: 4/24/2025 Posts: 12 Rating:
Hi Denilson, Thanks for the application sample. I want to ask, how to change the name of device diagnostics generated (please see screenshot). I have several PLC however they generate same name in the overview of diagnostics. Thanks for the attention. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 02/12/2025 09:09:35New subject after splitting |
2/12/2025 9:51 AM | |
Joined: 7/10/2024 Last visit: 4/25/2025 Posts: 170 Rating:
Hello SeedMagma! To change the name of the devices, so that it is easier for you to identify them, you can try changing the name as detailed in the following section of the manual. - Assigning a PROFINET device name
If you found this post helpul, I'd greatly appreciate your feedback with the rate function |
