3/11/2022 3:38 PM | |
Joined: 2/27/2008 Last visit: 2/1/2023 Posts: 20 Rating:
Hi Row113, you CAN use your tag "Status" in all JavaScripts of your faceplate in the same context (either events or properties, in this case events). Did you try it? Did it not work? Change to the next screen item and go there to the Global Definition Area: You will find again your tag "Status", it is also valid there..
see also the attached project. go to faceplate "fpUnified", the tags "Variable_x" from the global definition area are multiple used by local script of misc. screen items.. AttachmentfaceplateScriptsTags.zip (197 Downloads) |
