10/7/2022 8:30 AM | |
Joined: 10/3/2022 Last visit: 6/16/2023 Posts: 6 Rating:
Hi, In the old WinCC comfort panels it was possible to set the format pattern of an IO field to be 999.9, and thus limiting the upper value. E.g. if the value was 1000, it would show hastags to indicate that the value is outside its range. Is it possible to do somthing similar in Unified? I tried playing around with the Output format property, but haven't managed to produce hastags Best regards, Sondre ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/07/2022 11:32:16New subject after splitting |
