2/14/2025 8:14 AM | |
Joined: 5/29/2024 Last visit: 4/25/2025 Posts: 122 Rating:
Hola Sebastián! I answer your post with the following:
2/14/2025 8:45 AM | |
Joined: 1/21/2013 Last visit: 4/25/2025 Posts: 3775 Rating:
Hi sebastian_bueno49, According to your screenshot, you are using Alarm Logging and Audit Trail. I assume that both store their data on the X51 device. You should consider the amount of memory available by configuring your maximum log size. See "Logging data" in the documentation for details. See "Size of a log entry in the alarm log" for more information on memory usage. Kind regards |
