3/14/2025 6:03 AM | |
Joined: 1/21/2013 Last visit: 4/18/2025 Posts: 3764 Rating:
Hi Damian-CIM, The behavior you see is correct for your script. The AlarmResult object has many properties, and the AlarmText property returns the localized additional texts 1-9 of an alarm as an array, not the text of the alarm event itself. You should use the EventText property for this. Kind regards |
3/14/2025 8:32 AM | |
Joined: 6/24/2024 Last visit: 4/16/2025 Posts: 5 Rating:
Hi Stefan, That worked. Thank you so much for the answer. |
