9/19/2023 9:36 AM | |
Joined: 1/21/2013 Last visit: 3/18/2025 Posts: 3657 Rating:
Hi snounyTO, In principle, you can configure a WinCC Comfort Panel with a WinCC Unified Comfort ES license. However, this may only be valid for versions from V16 (the first TIA Portal version for which WinCC Unified was available). To clarify this, I recommend that you contact Siemens Technical Support by creating a new support request. Kind regards |
9/19/2023 9:37 AM | |
Joined: 7/19/2022 Last visit: 3/18/2025 Posts: 435 Rating:
Hello snounyTO, The WinCC Unified Comfort ES license only covers you up to TIA Portal V16, which is when WinCC Unified was born. In previous versions, this license does not cover the programming of other panels. You need a WinCC Comfort or WinCC Advanced license. In this link you can see everything I tell you: |
9/19/2023 10:41 AM | |
Joined: 10/14/2021 Last visit: 3/18/2025 Posts: 5 Rating:
Thank you guys for clarification. |
