10/20/2023 9:44 AM | |
Joined: 7/19/2022 Last visit: 1/17/2025 Posts: 433 Rating: (71) |
Hello Tomek1000, 1. Please verify in task manager that the service is running. ( See attached screenshot "REP_Pdf.jpg") 2. If REPExcelToPDFHost.exe is not running / available in task manager then please check the windows task scheduler. ( see attached screenshot "REP.jpg"). Please start the computer before ( startPDFHost will be executed at system startup) 3. If the service is running, the root cause is probably due to the system not being not up to date -> Then please update to newest windows and excel version and try again AttachmentScreenshots.zip (592 Downloads) |
10/20/2023 10:11 AM | |
Joined: 6/9/2022 Last visit: 3/20/2024 Posts: 11 Rating: (1) |
Neither REPExcelToPDFHost.exe doesn't exist in task manager nor startPDFHost in task scheduler. How to get it? |
6/5/2024 10:41 AM | |
Joined: 11/3/2023 Last visit: 1/7/2025 Posts: 29 Rating: (0) |
Where can I find REPExcelToPDFHost.exe? Raffe |
