1/8/2025 9:08 AM | |
Joined: 8/3/2009 Last visit: 2/7/2025 Posts: 14670 Rating:
Hello Nico R 14 I have done this the last days again. Check in the FAQ: https://support.industry.siemens.com/cs/de/en/view/109806850 Chapter 5 -> since V19 you have to export the CA and install it , then do a Restart of the PC and open the Unified Configuration, then you should be able to select the webserver certificate from your CA. (In my case this works) Bye Murof |
