7/17/2024 2:58 PM | |
Joined: 10/20/2020 Last visit: 4/1/2025 Posts: 2 Rating:
Bonjour, Je suis actuellement en train de créer un objet (vanne TOR) pour un Runtime WinCCUnified sur TIA V19. Il s'agit d'un SVG Dynamic (SVGHMI) que j'ai créé moi-même dans Inkscape. Or, j'ai un soucis : lorsque le runtime est lancé : le SVG pixélise assez rapidement quand on zoom. J'ai remarqué que cela n'était pas le cas avec les objets SVG de Siemens mais uniquement avec les miens. Quelqu'un aurait-il une idée? Merci d'avance ;) |
7/18/2024 8:02 AM | |
Joined: 1/21/2013 Last visit: 4/4/2025 Posts: 3726 Rating:
Hi actemium59, Please note that this is an English-language forum, and to allow international users to follow your question, please write in English only.
Are you sure that your graphic is pixelated? I know that in WinCC Unified some elements become blurred if the zoom factor is not 100%. This behavior has been corrected for some screen elements, but not yet for all. I know that there is currently a difference between SVGHMI, which is stored as a type in your library, and normal SVG graphics that are simply placed on the screen. So that might be an explanation for your experience. However, if you would tell us more about your experience, we might be able to tell you more about it. Kind regards |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
