10/16/2023 4:58 AM | |
Joined: 6/9/2022 Last visit: 12/5/2023 Posts: 11 Rating:
Hi, I'm trying to install the plug-in to excel reporting in TIA portal v16. I follow this video WinCC Unified V16: Installation of the reporting Excel Plug-in - YouTube but still I don't have the folder Excelmanifest. Tried to uninstall and install again. Any ideas, hints? |
10/16/2023 7:19 PM | |
Joined: 5/30/2022 Last visit: 12/7/2023 Posts: 443 Rating:
Hi Tomek1000,
Last edited by: Hazard_7 at: 10/16/2023 19:20:35If this information really helps, you could use the Rate function. |
10/20/2023 1:43 PM | |
Joined: 8/3/2009 Last visit: 12/11/2023 Posts: 11813 Rating:
Hello Tomek1000 do you have run the WinCC Unified configuratino again after installing the Excel Plugin? herre you have to activate the MS Excel... also check the steps in the help system: https://support.industry.siemens.com/cs/ww/en/view/109813308/132541954571 Bye Murof |
