11/22/2024 11:25 AM | |
Joined: 12/7/2020 Last visit: 1/27/2025 Posts: 45 Rating:
I'd like to refresh this topic, I've got the same problem - Yes, Im using ES and RT PC V19 Update 3. In my case, i can simulate WinCC Unified, but i can't run local user managment on PC with only RT PC Installed. I tried all configuration manuals and FAQ's. No idea what i should do next. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 11/25/2024 08:30:44New subject after splitting |
11/23/2024 2:59 PM | |
Software: TIA Portal V19 Upd 3 WinCC Unified RT PC V19 Upd 3 I tried to reinstal WinCC Unifed PC, and I tried to apply the fixes from this FAQ: https://support.industry.siemens.com/cs/sa/en/view/109774151 When I try to login to UMC ( https://<devicename>/UMC) tt looks like I'm logged in to an account with no name: I also tried to make new certificate by in Certificate Menager. Is it possible that there is problem with my OS. On my Engineering station (Where everything works ok) I've got Windows 10, on client PC the OS is Windows 11. |
Last edited by: Scyzoryk96 at: 11/23/2024 15:05:54Add info about OS Last edited by: Moderator_Lan at: 11/25/2024 08:28:57link optimized |
