12/27/2019 10:53 AM | |
Joined: 9/23/2005 Last visit: 2/2/2023 Posts: 4177 Rating:
Hi, “Simple Samples” are small projects that demonstrate simple features. The target is giving a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps. Recipes (Parameter set) are an important tool for process operation, regarding to transfer and manager machine / plant parameters sets. This sample program shows a simple 3 variables S7-1500 Parameter set been controlled by a WinCC Unified Application Configuration main steps: The main steps are showed in the follow diagram: PLC DataTypes | |---------------- | | V V PLC Tags HMI User Data Type (Project library, types) | | |<-------------| | | V | HMI Tags | | | |<-------------- | V Parameter Set Types | V Parameter Set Object (Screen) The detailed configuration steps are displayed in the Help System, under, Information System, Visualize process, Visualizing processes with WinCC Unified, Configuring Parameters Sets (RT Unified), Creating a parameter set type with elements via a PLC user data type. Project (.zap16 ziped as .zip) AttachmentRecipes2.zip (761 Downloads) |
2 thankful Users |
