12/27/2019 8:01 PM | |
Joined: 9/23/2005 Last visit: 1/28/2023 Posts: 4176 Rating:
Hi, “Simple Samples” are small projects that demonstrate simple features. The target is giving a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps. Screen windows is an object that could be used as substitute of several others:
TIP: The screen name called by the screen windows is set in the property: General, Screen. It could be set as constant, linked to a string tag or configured by scripting. TIP: you can control the called screen from inside or outside. the FAQ SIMATIC WinCC Unified - Tips and Tricks for Scripting (JavaScript) https://support.industry.siemens.com/cs/br/pt/view/109758536/en Chapter 5.4.2 shows how to do it. This sample program shows how to use screen windows in a simple way to do it Project (.zap16 ziped as .zip) AttachmentScreenWindows.zip (1039 Downloads) |
Last edited by: Denilson Pegaia at: 12/27/2019 20:05:08Last edited by: Denilson Pegaia at: 12/29/2019 14:14:40Last edited by: Denilson Pegaia at: 02/15/2021 15:19:53Denilson Pegaia |
5 thankful Users |
1/8/2020 4:11 PM | |
Joined: 2/14/2012 Last visit: 9/15/2022 Posts: 4 Rating:
Gracias! |
